This discussion topic is read only Discussion topic: Sky Q mini box no longer connecting
This message was authored by: Ab214
We have a new router (without a WPS button) and we can no longer connect our Sky Q mini box - have tried all the suggestions & none work. Seems to be a problem with connecting to the new router as it won't recognise it & keeps searching for the old one - how do we change to the new router? have tried through settings and all obvious ways mentioned on forums.
Any suggestions?
Locked
Re: Sky Q mini box no longer connecting
@Ab214
Most domestic router hardware does have WPS somewhere, either as a physical button or through a software interface.  If you've changed to a Sky Broadband Hub, the button is cleverly concealed low on the right hand edge as it faces you.
This message was authored by: bob1234
@Ab214Unless it is a Sky router you can't connect it via WPS. However you can WPS the mini box to the main box.
However Sky routers do have a WPS button, cunningly hidden at the bottom.
Locked
