This discussion topic has been answered Discussion topic: Sky Q mini box keeps losing connection every 5-10 minutes
Message posted on 17 Dec 2023 10:52 PM
I've had a sky Q mini box upstairs for a few years never really had any problems just connectivity every now and again. The last 2 weeks it's constantly losing connection every 5-10 minutes. I've tried all the usual unplugging at the mains and restarting, following the settings for reconnecting to downstairs main box, reset downstairs main box, etc. any other suggestions?.. please it's driving me mad. Thank you 🙂
Message posted on 28 Jan 2024 10:56 PM
In the end I had to have a sky engineer come out, he did a connectivity test and found that the 2 boxes had a week signal (strange as it's been fine for years) so he set up a booster half way between the boxes and I've not had this problem since 🙂 give them a call to come out.
Message posted on 18 Dec 2023 07:34 AM
Re: Sky Q mini box keeps losing connection every 5-10 minutes
Hi @Charlie0911 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, then do the same with the Mini box?
Message posted on 28 Jan 2024 10:45 PM
I have exactly the same problem, been ok for years then connectivity drops out every 5 mins or so , pulled plug , rebooted 100 times , unplugged router still no good 😡
Message posted on 28 Jan 2024 10:57 PM
@Steve046 sorry I posted a reply above and forgot to tag you in it.
Message posted on 28 Jan 2024 11:24 PM
Hi did he say why after years of being ok that you needed a booster , heard some old main q boxes were getting changed !! I've fibre and my internet is like 250+ upload and 250 + download speeds and everything else works fine on WiFi !!?
Message posted on 30 Aug 2024 11:17 PM
I have a Main Sky Q box and 2 mini boxes. I am on a 3rd party internet (Karoo - Kcom) and everything has been fine for ages.
Recently the mini boxes starting dropping signal and needed reactivating. In the last few days the main box has started dropping it's internet signal as well.
I have rebooted all boxes. I have manually updated the main box software, I have reset the router and the main box and still all boxes keep losing connection.
Message posted on 25 Nov 2025 07:04 PM
having the same problem, we've moved much newer smaller property and had fiber put in, the mini says its connected but keeps dropping out, the smart tv works perfect. I thought it was the new router, all works perfect if its connected via cables. very very frustrating.
Message posted on 25 Nov 2025 07:09 PM
I unplugged everything for half an hour - including the power to the junction box where the fibre cable come in to house, not just the router etc. All good now.
