2
This discussion topic has been answered Discussion topic: Sky Q mini box keep disconnecting, resetting has gone into frozen position. Remote control unpaired.
This message was authored by: Add10
My Sky Q mini box keep losing connection with the primary Q box, it reached point re connecting frequently, I reached for Sky support under help, sky support, recommended resetting the minibox, done that, New problem now the remote control lost pairing with the minibox , the mini box frozen on screen "accessibility on sky Q," with background music , non functional, rebooting it and resetting it , yoielded no resumption of connection or change the snake fozen screen . Tried to stick photo on this page but will be only attached until discussion started. Anyone experienced similar problem?
sky engineer booked in 3 weeks! , sky tech promised to compensate for lost service,  sky tech recommend replacement of mini box, I have to to pay first to issue replacement,the call centre at India , it took nearly 2 hours , putting on hold over 10 times as they lack experience , knowledge or authority
This message was authored by: Laing1 Answer
Re: Sky Q mini box keep disconnecting, resetting has gone into frozen position. Remote control unpai
@Add10 to fix the problem in bold
try the following...
Unpair their Sky Q remote from the box by holding 4&6
Wait for the remote to flash you should then be able to dismiss the information screen by clicking on Skip & set up later
Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control your TV.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Add10
Thank you, it cleared the frozen screen
back to normal. The remote control back on too.
