Discussion topic: Sky Q mini box is not responding to the remote control.
This message was authored by: Paula+Wilk
I have tried new batteries in the control and tried the controller from my main box and it will not work.
Re: Sky Q mini box is not responding to the remote control.
@Paula+Wilk Have you tried rebooting your main Q box ie
then
rebooting your mini box see if that helps
if not you could Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
Hi @Paula+Wilk
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
This message was authored by: jillbond123
Do you me press 7 and 9 on main Q box. I'm presuming so if mini box isnt responding.
Do I do this with mini box remote and main Q box?
This message was authored by: MartynFisher
I have tried new batteries and the control from my main box.  Still won't respond.  I have also used the mini remote control on my main box downstairs and it works
The volume control on the remote control still works.  So there is nothing wrong with the remote.
I believe the sky Q mini has failed
This message was authored by: SteveWebber
My SkyQ mini remote wasn't responding but contolled the TV.
The Sky Q mini  was brand new , only installed yesterday.
I found one of the batteries had a dirty - tenminal.
I cleaned the bottom of the battery.
I then found when I pressed 7 and 8 together the Led flashed.
I then pointed it at the box and pressed 1 and 3 together.
It flashed again and the remote worked fine.
