Discussion topic: Sky Q mini box freezing and jumping - just been replaced
Message posted on 03 Jan 2024 08:34 PM
My Sky Q mini box was replaced just before Christmas by an engineer as it was freezing and jumping on both live tv and recordings.
However the problem is still happening even with a brand new box. There are no issues with the main box only the mini.
I have an engineer booked again but what could the problem be? We've had sky for over 8 years in this house with no issues until recently.
Message posted on 03 Jan 2024 08:38 PM
Re: Sky Q mini box freezing and jumping - just been replaced
Hi @teelula
Reboot the mini as above.
Message posted on 03 Jan 2024 08:44 PM
Thanks I've tried this numerous times as well as doing the system reset which seems to work temporarily but needs done 2-3 times in a row.
I don't understand why the problem as just started as nothing about the setup of my WiFi or broadband has changed.
Message posted on 13 Feb 2024 09:46 PM
After being at my wits end with the constant freezing and crashing, I called Sky and a very helpful Techie talked me through how to load the latest software version on the main and mini boxes. Fingers crossed but after about 10 days, the improvement has been dramatic. Not saying it will solve everyone's problems but it's certainly worth considering.
Message posted on 14 Feb 2024 08:01 AM
Interesting. They should update themselves but useful to know it's worth checking that and made such a difference. Thanks.
Message posted on 19 Feb 2024 05:38 PM
Knew I spoke too soon. My mini boxes, which have worked pretty much without any problems since reloading the software, have started to freeze and judder again. Could this be as a result of another overnight download by Sky which has screwed things up again. Who knows?
Message posted on 19 Feb 2024 06:47 PM
No, updates to the Q software are very infrequent.
