6
This discussion topic has been answered Discussion topic: Sky Q mini box freezes on Accessibility Settings Screen
This message was authored by: DavidMcK1
Hi everyone - I'm just getting around to setting up TVs, Sky boxes etc.. after moving home.
My main TV and Sky Q box are all working fine as is one mini box.  However, when I try to set up a second mini box then it freezes on the 'Set Up Accessibility Settings' screen and I cannot click any of the options on this screen - it's just frozen.  To get it to that point then I also have to push the button on the front of the box to get the light to go green - it won't turn on with the remote.
I have rebboted the main Sky Q box and the mini box after everything has come back up but the same scenario occurs.  Can any one help.  The mini box was working fine before I moved house.
Many thanks.
This message was authored by: Laing1 Answer
Re: Sky Q mini box freezes on Accessibility Settings Screen
Many thanks.
@DavidMcK1 try doing the following
Unpair their Sky Q remote from the box by holding 4&6 the light on the remote should flash
Then dismiss the information screen "Skip & set up later"
Then Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try resetting the remote by pressing 7 &9  on the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control the TV.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Many thanks.
Avatar for DavidMcK1
Thank you - that worked brilliantly.
This message was authored by: James+Morris
very helpful and solved the problem. thank you.
This message was authored by: Geesabrek
Brilliant, all sorted, many thanks
This message was authored by: Jacey28
I've tried that but it's still stuck on the accessibility screen. Any other suggestions?
This message was authored by: Skybiz
Absolutely brilliant.  I had tried everything else. Changed batteries. And followed as you suggested
Worked well . The reason I had the problem was because of a change of routers.
