Discussion topic: Sky Q mini box cant connect to main box multiple times per day and the internet keeps dropping
This message was authored by: Deananthony
Every single day our Sky Q Mini box cant connect to the main box and we have to reset everything.  I upgraded our internet a few months ago to the best possible and since upgrading our internet is slower and drops out on all devices 2-3 times per hour.  According to diagnostics there are no issues, however the internet is dreadful.  It is not a big house, so there is no excuse.  Certainly not worth the £130 per month sky are taking from me.
Re: Sky Q mini box cant connect to main box multiple times per day and the internet keeps dropping
Hi @Deananthony
Reboot the mini as above.
Avatar for Deananthony
Thank you for taking the time to reply.  Unfortunately, everything you have explained is exactly what we have to do, multiple times per day.
Who is your Broadband supplier @Deananthony ?
Have you also carried out the following:-
Wait until the router is completely back and running and then try a Network Reset found in main Q box Home - Settings - Setup - Network.
Thank you.  Everything is Sky.  I have tried what was suggested and within 15 minutes the same thing happened
