Discussion topic: Sky Q mini box buffering/ freezing but only when watching terrestrial t.v through the mini box.Its s
Message posted on 27 Oct 2024 08:56 AM
Mini box buffering / freezing when watching BBC and ITV.... however no issue on the main box. All other channels no issue. Any suggestions I have rebooted more than once ??
Message posted on 27 Oct 2024 09:31 AM
Re: Sky Q mini box buffering/ freezing but only when watching terrestrial t.v through the mini box.I
Hi @And11
Reboot the mini as above.
