Discussion topic: Sky Q mini box B001213A010176 frozen Not working
Message posted on 16 Nov 2024 12:25 PM
Sky mini box not working it's frozen
Message posted on 16 Nov 2024 01:08 PM
Re: Sky Q mini box B001213A010176 frozen Not working
Hi @Bobdenor45
Reboot the mini as above. If the Mini does not come on with the remote then press the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
With the mini box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
