Discussion topic: Sky Q mains lead SP170 or SP171. What is the difference?
Message posted on 25 Jul 2024 06:08 PM
I have an SP170. Will an SP171 work with my Sky Q 2TB Box
Message posted on 25 Jul 2024 06:35 PM
Re: Sky Q mains lead SP170 or SP171. What is the difference?
@relwob If im not mistaken aren't these for communual setup if they are then @Godfrey is best to advise if they are both compatible
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 25 Jul 2024 06:46 PM
Hi @relwob Probably a different manufacturer.
Message posted on 25 Jul 2024 06:47 PM
As I understand it the SP170 / SP171 devices are the power supplies for the Sky Q V2 receiver.
Godfrey.
Message posted on 25 Jul 2024 07:56 PM
Godfrey.
@Godfrey so what are power supplies that i'm mixing them up with as aren't their power supplies that help power the communual system ?
Message posted on 25 Jul 2024 09:14 PM
@Laing1 The Power Inserters that were originally used to remotely power the Unitron dCSS-422 Sky Q Plug-In adaptors were SP160 / SP161.
Godfrey.
Message posted on 25 Jul 2024 09:16 PM
Godfrey.
@Godfrey thank you so easy mistake on my part then 😀
