Discussion topic: Sky Q main box won’t reboot after shutdown has to be disconnected
Message posted on 13 Apr 2024 11:16 AM
Hi - SkyQ box won't start up after eco shutdown has to be unplugged and restarted everyday
Message posted on 13 Apr 2024 11:18 AM
							Re: Sky Q main box won’t reboot after shutdown has to be disconnected
What time are you seeing this? Have you changed the standby setting from eco to none or active to see if that makes any difference?
Message posted on 13 Apr 2024 11:23 AM
Hi @LozJ
Message posted on 13 Apr 2024 11:52 AM
Yes I've tried changing the eco settings but still the same issue - it makes a whirring sound (like a fan) - and won't boot until it's unplugged for 15 secs - fan stops and then reboots 🙄
