Discussion topic: Sky Q main box is not showing recordings or catch up tv
This message was authored by: Jon1276
Live tv and external apps are fine.
WiFi connection has been reset and is fine.
Re: Sky Q main box is not showing recordings or catch up tv
@Jon1276 are you getting any error messages ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Jon1276
No error messages. It read Technical Fault on the reduced screen, until I reset the router and Q bix. But problem persists.
Hi @Jon1276
Work through the following link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
