Discussion topic: Sky Q looses wired network connection
Message posted on 11 Dec 2023 11:58 PM
Problem thats just started today 11/12/23 in that the Sky Q box looses network connection.
Box is wired to a switch, all other devices work on the switch, to resolve the issue i have to power cycle via the main plug. Issue returns after a while.
Tried resetting the network
Tried connecting box via Wi-Fi same issue
Switch HP 1920s
Wifi Ruckus
Internet via Sky
Software issue rather than hardware as its all been stable for 2 years or so, any ideas?
Message posted on 12 Dec 2023 12:34 PM
Re: Sky Q looses wired network connection
Hi there, SJ46. I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Message posted on 12 Dec 2023 03:40 PM
I have exactly the same issue as of yesterday. Hard wired, box says there are no issues (when checking network status), yet can't view any on demand content/tabs.
Tried changing to WiFi temporarily, restarted router, sky q box. Hard reset both (pulling power) and still the issue persists.
Had no issues before now either 😐
Message posted on 12 Dec 2023 06:28 PM
Tried changing DNS server?
Message posted on 13 Dec 2023 03:58 PM
Yep, tried changing DNS between two secure DNS providers and also just 8.8.8.8/8.8.4.4. Nothing has worked unfortunately.
Think I'll just need to call to get a replacement box at this rate.
Message posted on 13 Dec 2023 04:08 PM
Having the same issue last 3 days. 2 resets yesterday and 6 so far today 😞
Was firmware just recently updated?
Message posted on 13 Dec 2023 04:13 PM
On the phone to support atm.
Firstly hadn't realised my box's storage was 100% full, so deleted a lot of old stuff I didn't need anymore (they recommended bringing below 80%).
Then was asked to update the software (Settings > System Info > Software Version > Setup).
Waiting for the update to complete at the minute and then doing a power cycle after so will let you know how that goes.
Message posted on 13 Dec 2023 04:27 PM
The update does literally take about 10 minutes to download btw if you try it yourself :').
Didn't fix the problem for me though, so still on the phone.
Message posted on 13 Dec 2023 05:11 PM
Mine is on
Q230.000.14.00L (5nf3ptk)
I think thats the latest FW and the one that seems unstable on the Mini Q's as well.
Message posted on 13 Dec 2023 05:51 PM
Same. Have gone through a whole bunch of troubleshooting with the engineer, including a network scan (which requires broadband connection) that passed and he was able to receive the results of that scan, so network connectivity is OK as expected.
Factory resetting now as a last resort otherwise they'll send a replacement box.
Message posted on 13 Dec 2023 06:08 PM
Just to align with the original post:
Sky Q 1TB
Patched in to NetGear Switch which is in turn patched directly in to TPLink Archer VR2800 Router
Openreach FTTP (Sky BB)
Factory reset completely broke box - just boots to blue screen with no information so the box is being replaced.
Message posted on 13 Dec 2023 06:54 PM
Sky Q 1TB
Patched in to NetGear Switch which is in turn patched directly in to TPLink Archer VR2800 RouterOpenreach FTTP (Sky BB)
@Gex is it a managed or unmanaged switch
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 13 Dec 2023 06:56 PM
Unmanaged, but we tried bypassing it and still had the same issue. Also same issue on WiFi (so bypassing switch).
Cheers,
Matt
Message posted on 13 Dec 2023 07:03 PM
Unmanaged, but bypassed it via WiFi and wired to no avail.
New box being sent tomorrow.
Message posted on 13 Dec 2023 07:05 PM
@Gex unmanaged are fine Sky Q doesnt like managed switches
