Discussion topic: Sky Q keeps freezing on play back of recordings, ususally as an add break starts
This message was authored by: DCO
Sky Q keeps freezing on play back of recordings, ususally as an add break starts, you can't fast forward it just loops back to the minute if froze. The only way to get back to what you were watching is to unplug and restart, this has happen twice today, and at least once a week over the last month.
Re: Sky Q keeps freezing on play back of recordings, ususally as an add break starts
Hi @DCO
