This discussion topic has been answered Discussion topic: Sky Q keeps dropping TV picture
Message posted on 06 Sep 2023 06:10 PM
The picture on our tv keeps dropping out for 1-2 seconds.
It happens when watching any tv channel via the Sky Q box
tests show the signal to the dish is fine and the weather is 'normal'
any ideas 💡 perhaps it's time for a new box as this one is around 8 years old?
Message posted on 06 Sep 2023 07:27 PM
Not necessarily the box @MWH1
First thing to try is a different HDMI lead.
If this the same
If this the same
Message posted on 06 Sep 2023 07:39 PM
Re: Sky Q keeps dropping TV picture
@oldfella Thanks so much- will give that a try
