Discussion topic: Sky Q keeps changing from Ethernet to Wifi
This message was authored by: MikeRN
So, recently my Sky Q 2TB box keeps dropping my wired connection and switching to my wifi network, the issue is my wifi is poor, which is why most of my house is wired.
I have turned the wifi off on the box in the engineers menu, but it still keeps reverting to wifi. I go back into the engineers menu and it is still turned off!!!
Suurely the boxes should be designed to go to wired as default, like any other device with a LAN port? These are stupid. From what I have read this is a common issue. It is now worse, it doesn't stay on my stable wired connection now for more than 30 seconds. It is getting a joke now and I am running out of ideas other than doing a factory reset, which I don't want to do for obvious reasons.
Why is this able to happen, surely my setting choice should override any other?
This message was authored by: Mr+Flibbles+86
Re: Sky Q keeps changing from Ethernet to Wifi
This message was authored by: Addie15
Update-We are closing this invite now due to no response within 48 hours. If you still need help, please let us know so we can re-escalate this for you. Thanks.
