Discussion topic: Sky Q issue with watching a program that hasn't finished recording
This message was authored by SteveJ1967 This message was authored by: SteveJ1967
I have just switched to SKY Q (from SKY+)  and when I start watching a program that hasn't finished recording it doesn't carry on recording the show and simply stops at the point I join.  E.g. program is 90 minutes long and I start watchin from the beginning off my recordings which is say 46 minutres into the live porgram.  Then I discover that 46 mnutes into my watching the recording comes to end and the final 44 minutes is nowhere to be found!
Re: Sky Q issue with watching a program that hasn't finished recording
Hi @SteveJ1967
Don't really understand what you are doing to make that happen.
There should be no issue with the program recording to the end of the scheduled time.
When you start watching where are you going to select the recording to play from the start?
Next time you start watching a recording once it is playing, press the up button (above the central select button) and you see the Playbar at the bottom of the screen.
You should see the progress of the recording including the point you are watching.  The progress bar will be red for the amount of time that the recording has been running and will also indicate at far right the total amount of the finished recording.
SteveJ1967
@oldfella thanks.  I select play from the start once I have selected from my available recordings. Appreciate that the recoding will not have finished.
That's clear @SteveJ1967
But if you bring up the progress Playbar while watching you can confirm at any during playback that it is still recording until it's scheduled end time.
If it is then it will be available to watch till the end.
SteveJ1967
@oldfella as to your comment below, initially it stated the full program length but as stated this did not materilase and program ended after 46 of the required 90 minutes
