Discussion topic: Sky Q issue - can’t get channel 5
This message was authored by: Victor+Edwards
Hi
cant get channel 5 on sky Q any ideas
Re: Sky Q issue - can’t get channel 5
@Victor+Edwards
Any error message seen?
Avatar for Victor+Edwards
Yes - says a problem with my Satalite dish but there in t a problem
@Victor+Edwards
A “no satellite signal” message relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
If you’re on a communal dish you’ll need to liaise with your landlord or building management company who will deal directly with their approved engineers.
Hi
ok I'll ask landlord  to check communal dish - thank you
