Discussion topic: Sky Q isn’t working. Remote works as normal, my TV works as normal but when I turn Sky on nothing.
Message posted on 27 Jul 2024 09:40 PM
Sky Q doesn't work. Remote works fine, red light on the box in the middle but normal green light is on. No TV
Message posted on 27 Jul 2024 09:45 PM
Re: Sky Q isn’t working. Remote works as normal, my TV works as normal but when I turn Sky on nothin
Hi @CD104
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box.
