Discussion topic: Sky Q - intermittent usage to upstairs mini box - would a sky Q booster help?
Message posted on 30 Mar 2024 09:50 AM
Hi - I have a Sky Q 2tb main box with 4 mini boxes attached. The ones downstairs all work with no issues.
However the upstairs mini box often struggles with the dreaded 'you cannot watch TV due to connectivity' blue screen or a similar message saying there is a problem connecting with Sky Q box. Happens when watching either normal Sky channels, recordings or one of the streaming apps via Sky.
It's only used upstairs in the late evenings and seems to have very intermittent periods of poor connection (no pattern).
I've done all the various troubleshooting steps and resets/reactivations with little difference made - I do have sky broadband guarantee - but due to the intermittent nature of the issue it doesnt really register as an issue for Sky....
So I'm at the point of wondering if I buy a Sky Q booster?? and if so which one, as there seem to be different year based models available to buy... advice please!
Message posted on 30 Mar 2024 10:06 AM
Re: Sky Q - intermittent usage to upstairs mini box - would a sky Q booster help?
Hi @AKT69
Have you connected the problem mini to the Nearest of your other Q devices?
That's the main Q box the Sky router or another connected mini.
Connect by WPS following a Network reset on the problem mini.
You will be asked to press the WPS button on the nearest Q device (not the mini as the Network reset will start the mini WPS automatically).
As you are on Sky Broadband and if the Router or another mini is nearer than the main box then you can try pressing WPS on this instead of the main Q box. If you do use the router then make sure you press the Sky router WPS button and not the router reset button.
Failing all of the above you may need a Sky Q WiFi Booster to position midway between.
your main Q box and the mini and you will need to contact Sky directly. They should supply these free of charge to aid Q connectivity problems
Message posted on 30 Mar 2024 10:20 AM
Thanks @oldfella - yes I dont know how many times I've done the various resets as youve outlined (often late at night which is fun coming downstairs !)
What I find odd is that it always seems to be worse around midnight, as if my sky broadband or Q service weakens late at night.
The Sky Q main box is also quite old and hot/sluggish, but my chances of getting Sky to change it I'm guessing will be limited
Message posted on 05 Aug 2025 03:13 PM
Neither I nor "expert" can make it work. PLEASE schedule an Sky Engineer to fix it. Thank you
Message posted on 05 Aug 2025 03:17 PM
I do not know
Message posted on 05 Aug 2025 03:19 PM
I need a Sky engineer to visit. Local "experts" have failed
Message posted on 05 Aug 2025 03:22 PM
@WATCHIT1 wrote:I need a Sky engineer to visit. Local "experts" have failed
You'll need to call Sky then.
Message posted on 05 Aug 2025 04:32 PM
@WATCHIT1 Afraid you are not contacting Sky's customer services on here, this is a customer to customer forum where customers help each other.
as @PandJ2020 says you need to contact Sky
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
