Discussion topic: Sky Q installed on a Skyglass TV
Message posted on 01 Jul 2025 08:39 AM
I have had sky Q installed yesterday on a sky glass Tv and now none of the other TV's work in the house which has freeview. Is there a video or any help plwase
Message posted on 01 Jul 2025 09:15 AM - last edited: 01 Jul 2025 09:16 AM
Re: Sky Q installed on a Skyglass TV
@Jbecks9 wrote:I have had sky Q installed yesterday on a sky glass Tv and now none of the other TV's work in the house which has freeview. Is there a video or any help plwase
Freeview requires an aerial connection on each TV you want to receive it on. Did you have Sky+ with an aerial distribution system before you changed to Sky Q? If so, it will no longer work as it did before.
Also, when you say you have a Sky Glass TV - are you just using it as a monitor/sound system with a Sky Q box attached to it via HDMI?
Message posted on 01 Jul 2025 10:40 AM
Hi @Jbecks9
If you have changed from Sky+ then there is not any RF (terrestrial outputs ) on Sky Q so you will have lost the ability to use the Q box for RF out.
You will need to buy a simple powered aerial splitter to take the input from your terrestrial aerial and feed it to your main TV and also to all your other Televisions. Something like the following
Message posted on 01 Jul 2025 10:47 AM
Yes we are using the sky glass tv as a monitor sound system and the sky Q is attached to hdmi.
I just need to know how to connect all freeview on other tv's. I am guessing we had a aerial distribution system but all other TV's in the house have no Freeview available so I am guessing I need to do something
Message posted on 01 Jul 2025 12:09 PM
Then you need an aerial splitter as per my post @Jbecks9
