Discussion topic: Sky Q in house and caravan?
This message was authored by: OksanaB
We have moved to a house with a static caravan/unit on the property, not far from the house, about two meters away. Is it possible at all to get Sky Q in the house and the caravan? Would I need two satellite dishes? Would I need sky q in the main house and a mini box in the caravan? Also do you need an aerial for sky?
Re: Sky Q in house and caravan?
Hi @OksanaB   With a Multiscreen subscription you can have a Mini box connected by WiFi to the Main Sky Q box in the house. Only one dish connected to the Main box in the house is required. The important distance is from the Main Sky Q box to the Mini box, which must be a 5GHz WiFi frendly signal path to the Mini. Note make sure a Mini box is ordered with the Multscreen subscription.
Or run ethernet from the caravan to the house.
