Discussion topic: Sky Q freezes more and more often
Message posted on 30 Dec 2025 06:10 PM
Sky Q box freezes more often now and especially after being off a few hours. Stays off and needs to be mains removed then rebooted often. Is there anyway of getting a new box as this one is more than a decade old, way older!
Message posted on 30 Dec 2025 06:42 PM
Re: Sky Q freezes more and more often
@bigflash24 wrote:as this one is more than a decade old, way older!
Hi @bigflash24 All Sky Q boxes as now old. First introduced in 2016.
Message posted on 30 Dec 2025 07:17 PM
Gee, that's helpful
Message posted on 30 Dec 2025 07:23 PM
Hi @bigflash24
Message posted on 30 Dec 2025 07:33 PM
Done all this exactly already
