Discussion topic: Sky Q engineers .What to check before the appointment
Message posted on 10 Feb 2025 06:32 PM
In an earlier post I asked if it was feasible to set up Sky Q with only one cable from the LNB. This to avoid running a second cable through our long house to where our current old fashioned Sky Box/ with single cable is sited.
My question relates to accepting The Sky Q requirement for 2 cables from the LNB. If we sited the main Sky Q box in an unused room room with TV close to the Sky dish/LNB where it would be easy to run a second cable discreetly , would we get the same benefits of Sky Q in our living room where only a mini box would be sited ( I understand that this only requires an internet connection)
Message posted on 10 Feb 2025 06:41 PM
Re: Sky Q engineers .What to check before the appointment
hi @RESROC
The main restriction is that only the main box is capable of 4K/UHD
For set up and in case of problems the main box would also need to be able to be hooked up to a display - although this need not be permanent
After that the mini works via ethernet or wifi
YOu probably know but use of one or more minis need a multirrom subscription
Message posted on 10 Feb 2025 06:42 PM
Yes, the only limitation is that mini's do not support UHD if you have that requirement.
Message posted on 10 Feb 2025 09:13 PM
Finally I understand, many thanks. Will have to get a youngster to crawl through a lot of roof space , with at least the original cable to guide them !
Message posted on 10 Feb 2025 10:21 PM
@RESROC wrote:Finally I understand, many thanks. Will have to get a youngster to crawl through a lot of roof space , with at least the original cable to guide them !
I'm pretty sure the Sky team are not allowed to enter the loft
