Discussion topic: . Sky Q drops the WiFi connection a lot of times.
Message posted on 12 Oct 2025 11:31 AM
My sky q box loses its connection regularly. It's not a WiFi problem as all other devices we have work when this happens. It's really frustrating as we are struggling to watch tv
Message posted on 12 Oct 2025 11:42 AM
Re: . Sky Q drops the WiFi connection a lot of times.
Hi @kristof1978 WiFi issues are notoriously difficult to resolve. Have you considered power line adapters to bypass the WiFi and get a solid signal to the router. I would power reboot everything, including the broadband router (it doesn't matter if other devices work).
Message posted on 12 Oct 2025 11:44 AM
We have power lines in the house. It happens to our sky q box upstairs so I think it's got to be a sky box problem?
Message posted on 12 Oct 2025 02:21 PM
@kristof1978 If Sky is not your broadband provider then any mini boxes you have(im assumming this is what you are talking about) wont connect to your router by wifi they need to be connected to your main box by wifi by using the WPS button on the boxes
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 12 Oct 2025 02:24 PM
Sky is our broadband provider. Our main box in the living room and mini box both keep getting disconnected. All other devices remain connected to internet so I can't see it being an internet fault?
Message posted on 12 Oct 2025 03:23 PM
@kristof1978 what Sky router do you have black or white ?
Message posted on 12 Oct 2025 04:50 PM
White router
Message posted on 12 Oct 2025 05:46 PM
@kristof1978 wrote:
White router
@kristof1978 ahh right so the white Sky max router is completely different to the older back router.
I'd sugest rebooting your router then on your main box do a network reset.
When you do this treat the router as a third party router and search for it by the ssid and connect to it with the wifi password on the router.
With the mini boxes these need to be connected to the main box by way of the WPS buttons to join the mesh system that the main box emits.
The old black router had software that allowed them to become part of the mesh system the main Q box emits but the new white router do not do this so need to be treated as you would with a third party router
Message posted on 12 Oct 2025 05:50 PM
Thanks,I will try that
