234
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Q download
Locked
This message was authored by: JNorrisSky
Re: Sky Q downloads disabled?
I'm with Utility Warehouse, same problem, still not resolved
This message was authored by: Richie641
Re: Have been able to download out with Sky Q box for a few days
Sky are aware and it is a global issue it seems. You are not alone. Many of us have raised similar points on here
This message was authored by: Veteran67
Good to know, many thanks Richie....
No one said it was resolved. So you can try the workaround or you can wait.
Re: Sky Q download
@Gaynor53 wrote:
Hi I have similar issue how do I update the talk talk
See the rest of this thread. Many posts explaining it.
We are also with Utility Warehouse and downloads do noy work
Re: Sky Q download
Best of luck all! Notifications off, outta here, plsreadthread thx.
This message was authored by: oldtvgirly
Re: Sky Q download
Some of us are a bit worried about messing about with router settings and would much prefer to wait it out, it's only the download that isn't working everything else is fine.
Re: Sky Q download
@oldtvgirly
That's fine. No one is forcing you to make the suggested changes.
Re: Download not working.
Are you Talk Talk or Utility Warehouse?
@JNorrisSky
If you use the @ symbol then the name of the person you're replying to like I have done above it makes the thread easier to follow.
Re: Sky Q download
I just changed mine to 1 1 1 1 and it's working ok, have noted the previous settings 👍
I just changed the DNS manually to 1 1 1 1 and it seems to be resolved
This message was authored by: RobertH2
Re: Sky q not recording from the home page
  • Should I do what others have done and change the dns setting on Sky Q box to 1.0.0.1? How do I do that, please? Does anyone know if Sky and/or Talk Talk are working on a fix-in which case perhaps I should wait?
Any help much appreciated.
R
Read the thread
Locked
Answered - Go to Answer
