196
This discussion topic has been answered Discussion topic: Sky Q download
Re: Sky Q download
@Wibbly-Woo wrote:
@Daniel0210 Sorry - you'll have to explain - should I not have changed the DNS or was that OK ?
Because I appear to have resolved it ...
Hi @Wibbly-Woo   You have not resolved it, you have used an "unofficial" workaround. If it now works, leave it alone.
Re: Sky Q download
@Wibbly-Woo wrote:
@KevNewMedia
Hello,
Could you please confirm exactly what you meant in your last sentence ?
"Please note that the workarounds being discussed are not ones that we can ask you to do."
Do you mean "DON'T CHANGE THE DNS settings" or what ?
@Wibbly-Woo I suspect it's simply that Sky can't commercially endorse any DNS provider other than themselves. .
Re: Unable to download Flipping Bangers series 2 - on Q
@Wibbly-Woo wrote:
@Chodley
is that 1:1:1:1 or 1:0:0:1 that DNS should be set to .... ?
both numbers have appeared in this thread
I used 1:1:1:1 and that appears to work
Either are fine. They are both highly reliable DNS servers hosted by Cloudflare.
This message was authored by: JNorrisSky
Unable to download any Sky movies or channels on demand
Since yesterday evening I have been unable to download any Sky movies or general programs 'on demand'.
it keeps saying 'download failed' no broadband, however the broadband is working fine.
i have even tried downloading latest software and telephoning for technical help.
Have been advised it could take 48 hrs, but no offer of compensation or reduction in subscription!! Poor service
Re: Sky Q download
@Wibbly-Woo wrote:
Why can Sky not send updates out to do this remotely ?
There must be thousands of customers affected by it ..........
Doesn't work like that. It's not technically possible plus this isn't a change that Sky would want to do. You should use your own ISP's DNS really, especially on your router, but this workaround has no real technical downside.
I'm sure between them and TalkTalk / any other affected ISPs, it will get sorted but if it was me affected, I wouldn't want to wait. Can always change it back in a month once the dust will have settled.
This message was authored by: Louisa01
Download not working.
Download is not working.
Full reset completed.
Broadband checked and sky confirms connected.
However try to download and it says no broadband.
Not sure what else can be done.
Re: Unable to download any Sky movies or channels on demand
@JNorrisSky
There are lengthy threads on the Sky Q and Sky+ boards. Which do you have?
Are you on TalkTalk? Many TalkTalk customers are reporting problems with Sky downloads at the moment, however the Sky download service is working as normal with other ISPs.
I have Sky Q
This message was authored by: Gaynor53
Re: Sky Q download
Hi I have similar issue how do I update the talk talk
Re: Sky Q downloads disabled?
I'm with Utility Warehouse, same problem, still not resolved
No one said it was resolved. So you can try the workaround or you can wait.
Re: Sky Q download
See the rest of this thread. Many posts explaining it.
This message was authored by: Richie641
We are also with Utility Warehouse and downloads do noy work
Re: Sky Q download
Best of luck all! Notifications off, outta here, plsreadthread thx.
Answered - Go to Answer
