Discussion topic: Sky Q doesn't work with max hub and powerline adapters
This message was authored by: Zg77
Just got the Sky max hub to replace a previous Sky hub.
When connected with powerline adapters so I can get wifi to Sky Q mini box in summer house I don't have any wifi to any Q boxes.
If I unplug the powerline adapters Sky q box works fine in the house with wifi.
Before getting the max hub my setup worked fine with powerline adapters. Now, it's Sky q in the house and no wifi to the summer house or vice versa.
Is there any way of sorting this?
Re: Sky Q doesn't work with max hub and powerline adapters
Make sure that the wiring to the Summer House is on the same wiring circuit as that to the Powerline device that is connecteed to the Router. Afterall, on these Powerline wifi extenders, the signal is carried through the house wiring.
I have just read your post again.. The problem is that your new Sky hub is designed to boost the signal to your SKY Box at the expense of giving out a weaker signal elsewhere. Changing your hub may not, in hindsight. been a good idea. I am with Vodafone, and use a Powerline extender to be able to get a mini box working in my shed which is more than 40 metres from the main Sky Q box.
