Discussion topic: Sky Q cutting out every couple of minutes
Message posted on 04 Oct 2023 03:33 PM
Sky Q is cutting out every couple of mins when watching live and recording.
I have turned off at mains for couple of hours, checked cables several times, checked viewing card was in correct and dust free, there are no abstructions to satellite dish. I even reset the broadband.
I have also ran a software update.
LNB type is on Wideband (personal dish not shared)
I'm at a loss on what to do to resolve this issue
Any help would be really appreciated
Thank you 🙂
Message posted on 04 Oct 2023 03:46 PM - last edited: 04 Oct 2023 03:51 PM
Re: Sky Q cutting out every couple of minutes
LNB type is on Wideband (personal dish not shared)I'm at a loss on what to do to resolve this issue
Thank you 🙂
Hi @G..
I assume the box is not excessively hot and is well ventilated and not stacked with other devices.
Message posted on 04 Oct 2023 03:47 PM
Explain 'cutting out'.
Picture going black or something else?
Message posted on 04 Oct 2023 06:52 PM
Thanks for reply so yeah screen goes blank for 1-2 seconds then continues with programme I'm watching
thanks 🙂
Message posted on 04 Oct 2023 06:53 PM
sounds like a dodgy cable
Message posted on 04 Oct 2023 07:04 PM
You any idea what cable it would be?
thanks
Message posted on 04 Oct 2023 07:37 PM
I will try this soon as I've finished watching bargain loving brits in the sun 🙂 thanks
Message posted on 04 Oct 2023 07:38 PM
I am sky staff haha I just can't work out the issue
Message posted on 04 Oct 2023 10:05 PM
Message posted on 12 Oct 2024 06:10 PM
I am having exactly the same problem , picture goes black & sound cuts out intermittently for a second or two , regardless of sky channel via satellite or app channel via internet. Did you resolve your issue and was it dodgy Cable?
DS.
Message posted on 26 Dec 2024 11:47 PM
Having same issue, all new box, cables etc, WiFi is good... I'm thinking this is a sky issue
Message posted on 27 Dec 2024 08:15 AM
@Carnmiester wrote:Having same issue, all new box, cables etc, WiFi is good... I'm thinking this is a sky issue
Wifi wouldn't cause that anyway
try it at 1080i - does it still happen?
