Discussion topic: Sky Q could not find Virgin Broadband router
Message posted on 15 Apr 2024 01:49 PM
Hi All, My Sky Q could not find my newly installed Virgin hub3 router, after faffing about for 30 mins, went into the router settings and discovered my techy son had disabled 2.4GHz wifi, only 5 GHz enabled when he visited at weekend. Reenabled 2.4GHz on router settings and what do you know Sky Q found my router. Put this post on as may help.
Cheers
Mark
Message posted on 15 Apr 2024 02:29 PM
Re: Sky Q could not find Virgin Broadband router
My understnanding is that with non sky bb the boxes will only connect to 2.4 and the 5ghz is reserved for communication between the boxes themselves.
Message posted on 15 Apr 2024 04:15 PM
@bemak187 your understanding is correct
LG 49SJ 810 V UHD TV, Google Pixel 10 Pro XL mobile
