Discussion topic: Sky Q connecting to Multimedia faceplate in new build
Message posted on 03 Feb 2025 02:03 PM
We are about to move to a new build that has Quadruplex Multimedia sockets. We asked the electrician how these worked with Sky Q but he just said that Sky would connect to it through a Wiska box on the outside of the house when they installed the satelite dish.
From all the forums I have read online it would appear that this type of socket in not compatible with Sky Q. Is that correct?
In the event that Sky Q can be connected to the socket, would they use a Wiska box or just drill a hole and use their own cables? Not to keen on holes in my new house!
Message posted on 03 Feb 2025 02:42 PM
Re: Sky Q connecting to Multimedia faceplate in new build
@HantsLady wrote:would they use a Wiska box or just drill a hole and use their own cables? Not to keen on holes in my new house!
AIUI the standard Sky install will simply drill from outside to inside and use mastic filler on the outside only. No boxes/plates at all.
Message posted on 03 Feb 2025 02:56 PM - last edited: 03 Feb 2025 03:19 PM
Typically Sky personnel won't touch a combination faceplate because it may well contain frequency filters that mess with the dish signal going to a main Q box.
Unfortunately developers fit such things as a (very cheap) 'value add' without any understanding of current satellite television technology (or basic concepts of data network topology)
You might have a corresponding spool of twin coaxial cable in the loft from 'Sat1' & 'Sat2', but a Sky installer can't use that at all, and heaven only knows where the other end of any cable punched-down on the ethernet socket is ; )
The 'aerial' socket on the left appears to be for Sky+ using a 'magic eye' solution for cabled distribution between rooms and so is a decade out of date...
