21 Oct 2023 08:33 PM
Very recently my main Sky Q box constantly throws me off the internet. Says it is connected to router, but not the internet. The same thing is happening to one of my sky mini boxes too. I reset and it works again for a few minutes. I've re booted my router and my Sky Q box but it's happening every few minutes and is driving me mad! Unable to watch Disney+ at all!
Can anyone help fix this for me??
21 Oct 2023 08:35 PM
Hi @justj50
You need to carry out a Network reset on the Q box.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
22 Oct 2023 09:14 AM
@oldfella thank you. I'm pretty certain I have tried this already, but I will try it again.
22 Oct 2023 09:19 AM
22 Oct 2023 11:06 AM
Posted by a Superuser, not a Sky employee. Find out more22 Oct 2023 04:07 PM
@oldfella It's plusnet, always has been. Nothing has changed.
22 Oct 2023 05:55 PM
Posted by a Superuser, not a Sky employee. Find out more22 Oct 2023 11:59 PM
Same thing happened to me tonight at 10.30pm. No internet on my wired system even though my local network was up and running fine. Treid a reset as instructed but it didn't help. Swapped out my network cables connected to my Q box and that didn't help either. Nor did power cycling my Q box or my fibre router. Weather was fine and dry and I've been home alone all night so no-one else to blame. Total mystery.
Approx 1 hour later my Q internet connection came back by itself with no explanation. But will it happen again?
It's obviously not a universal problem or this board would be burning up with it. Maybe there was some local issue here in east Berkshire which only affected Sky? Apparently a train of Starlink satellites was seen overhead earlier in the evening…Are they the culprits?
23 Oct 2023 08:51 AM
Posted by a Superuser, not a Sky employee. Find out moreNo they're not the culprits since they have both nothing to do with your internet connection nor affect the signal from astra (which is irrelevant anyway)
23 Oct 2023 09:33 AM
I've seen unofficial reports of wifi interference from Starlink but my Q connection is via ethernet. Any idea what else might have caused this local and Q-specific blackout?
Starlink discussion on Reddit
