Discussion topic: Sky Q box wont connect to internet
This message was authored by: Gemgems18
Sky Q box won't connect to the Internet. I have tried to reboot, unplug, and plug back in and still nothing.
Re: Sky Q box wont connect to internet
Hi @Gemgems18
If this is your Main Q box (not a mini) try a Network Reset found in main Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
This message was authored by: Merryn36
I'm having the same problem and seem to
be going round in circles to rectify the issue. Tried resetting and nothing is working
This message was authored by: MariaLucy
Internet connected but everything off line can't get anything on
This message was authored by: Nom2023
I don't have a button on my broadband router but is sky.
I have tried manually typing in password but isn't working.
@Nom2023 if you have the broadband hub the one that stands upright then the wps button is located on the right hand end of the router
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Thank you! Working now
This message was authored by: Rach26
Having the same issue spent nearly 40 mins on phone to sky for them to tell me they don't know what's going on but I can get an engineer visit but gotta pay for it.
