5
This discussion topic has been answered Discussion topic: Sky Q box won’t turn on
This message was authored by: DMD58
Sky q box won't turn on, remote doesn't have any lights on, have changed the batteries and still doesn't work, 7 and 9 together isn't working either
Re: Sky Q box won’t turn on
@DMD58 wrote:
Thank you, - have pressed the amber light - nothing happens ...
hi @DMD58
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box.
Hi @DMD58
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Avatar for DMD58
Level 0 icon
hi @DMD58
Avatar for DMD58
Level 0 icon
Thank you so much for all of your help - I will give the link a go and if not call them tomorrow. Thank you so much
Avatar for DMD58
Level 0 icon
Thank you so much for all of your help - I followed the instructions and it's working again now!! THANK YOU 😊
