Discussion topic: Sky Q box won’t turn on
This message was authored by: AshleaW
Message posted on 15 Feb 2024 04:22 PM
Sky Q box won't turn on, just has an orange light on it
Find out more
Message posted on 15 Feb 2024 04:23 PM
Re: Sky Q box won’t turn on
Hi @AshleaW
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
