Discussion topic: Sky Q box won't turn on, fan noise
This message was authored by N1k This message was authored by: N1k
Weve had a Sky Q 2tb box since the service was launched, mounted in a big open space behind the TV. Been in this position for over a year with no concerns.
Never had any serious issues with the hardware, but a few weeks ago, we would come down in the morning to find the box making a loud fan noise, and permanent in standby with the orange light. The box isn't hot, not even warm, even by the vent.
Managed to follow the online help to force a software update, but the issue reoccurred nearly immediately. We ended up getting a replacement SkyQ box pretty quickly (impressive), assuming this one was on the way out.
However, with the new box in place, the same issue reoccurred within days. It seems to be when the box goes into standby, during the day or night, the fan kicks in and can't be revived from standby.
Only fix is to pull the power, plug it back in and wait for it to run through the startup process.
Any ideas? Clearly unable to actually call sky. Very odd that the issue has occurred on 2 separate boxes.
Re: Sky Q box won't turn on, fan noise
Hi @N1k
Check your standby settings on the Q box.
https://www.sky.com/help/articles/using-the-standby-settings
Try the different options to see if any are better.
(Eco, Active or None)
If using None the Q box still needs putting into standby with the remote when not in use (Amber led)
N1k
Appreciate the response, but if this was caused by one of the 3 standby settings (which have not changed in years), then there'd be millions of people having the same issue every day. None of the standby settings have the "never actually leave standby but sit with fans running full" option.
N1k
By the way, was able to confirm that this occurs every time the Skyq box connects to the ethernet cable. Never been a problem before, but just recently started happening, and then again immediately on the replacement box. So no idea what is causing it. However, immediately occurs minutes after connecting it to the network.
N1k
How do I get support for this issue? Doesn't seem to be a technical support phone number, and the troubleshooting process just results in me getting sent new sky boxes..
This message was authored by Work+LCD This message was authored by: Work+LCD
Ours does exactly the same. Original box ran fine for 4 years, then started doing this. We've had a new Q 2tb box for 3 months and does exactly the same.
time to contact sky again.... it needs to be resolved.
This message was authored by Chodley This message was authored by: Chodley
I had this happen on a new box. Got it replaced
but recently read a thread that suggested it might be when the Q tries to run at 1Gb (which only the v3 box can do)
At one point I had an ethernet cable all the way through 3 rooms as a test, and that would have been a 1Gb port - I don't know if this was at the same time but it might have been. Right now I've got it connnected to a 100Mb only switch and have no issues so... coincidence?
so might well be worth trying to plug it into a cheap switch to test
