Discussion topic: Sky Q box won't stop rewinding or fast forwarding without pushing home button
Message posted on 30 May 2023 08:09 PM
When fast forwarding or rewinding recorded programmes Sky Q box won't stop when i push play, i have to push the home button then it stops and I can control the box again. Just a niggle but annoying.
Message posted on 30 May 2023 08:25 PM
Re: Sky Q box won't stop rewinding or fast forwarding without pushing home button
@Cyclops1688 Have you tried rebooting your main Q box ie
If this is a mini box it is happening on first reboot the main box then the mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 30 May 2023 08:27 PM
Yes i have rebooted numerous times, for other issues too as sometimes doesn't connnect to my mini boxes
Message posted on 30 May 2023 08:28 PM
@Cyclops1688 Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
Message posted on 30 May 2023 08:45 PM
hi @Cyclops1688
Do the recordings pause OK when you press the pause/play button - if not it sounds like a remote button issue
BTW As an alternative, voice control is very useful
handy controls are :
Skip nn minutes
Go To nn minutes
Back nn minutes
You can use hours, minutes & seconds or mix e.g. Go to 1hour 15 minutes
Skip nn minutes is very handy for adverts and you get used to the length on regular used channels (Many are around the 4 minute mark)
You can also say Go To Start
As well as "Pause" & "Play"
Voice control in general is very useful:
https://www.sky.com/help/articles/sky-q-voice-control-commands
Message posted on 30 May 2023 08:48 PM
They sometimes work sometimes don't.
