Discussion topic: Sky Q box won't respond to remote - here's what I've tried
This message was authored by: hanaku
I have:
- switched remote batteries to ones I know to be working
- disconnected the power to the box for 2 hours (the box starts fine but when the screen goes black and I have to press home, I can't go further as button presses aren't registering on the box)
- held 7 & 9 on the remote (nothing happened)
- held 1 & 3 on the remote
- held the power button on the remote
What can I do?
Re: Sky Q box won't respond to remote - here's what I've tried
@hanaku wrote:
I have:
What can I do?
Pressing & holding 7 & 9 should reset the remote & caue the red led above the SKY Logo button
If that doesn't happen you may need to get a new remote
You should also be able to use a virtual remote on SKY Go (this was on iOS only but now also available on android)
Avatar for hanaku
Thanks for your reply. Will Sky provide a new remote for free? The remote in the app doesn't give the option for the main Q box, even when it's temporarily providing signal to the TV after you plug it back in.
Hi @hanaku
Check the following link and it will lead to a form for a replacement remote.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment
