Discussion topic: Sky Q box won’t play recordings
Message posted on 01 Jun 2023 05:37 PM
For the past 3 days the sky Q box won't play recordings or load the home page without switching the box off and on again. It feels like it is on its way out
Message posted on 01 Jun 2023 07:02 PM
Re: Sky Q box won’t play recordings
Message posted on 01 Jun 2023 07:41 PM
Thanks - it has since gone completely kaput. New box on the way. Thank you for taking the time to help
