Discussion topic: Sky Q box won't connect to router
Message posted on 07 Oct 2024 07:07 PM
Message posted on 07 Oct 2024 07:22 PM
Re: Sky Q box won't connect to router
@Jhat wrote:
My skyQ box will not reconnect to broadband router, have tried several times, including performing a hard reboot of both skyQ box and broadband router.
Hi @Jhat
Message posted on 07 Oct 2024 09:06 PM
Hi,
Thanks, I have just tried this again, but still not connecting to router
Message posted on 07 Oct 2024 09:11 PM
Message posted on 07 Oct 2024 09:17 PM
Sky provides my broadband. Internet is working for other devices just not sky q box. When holding wps button in, takes ages for it to stop flashing then it just comes up with 'unsuccessful connection. please try again, or u may need to connect a sky booster. We already have a booster connected.
Message posted on 07 Oct 2024 09:22 PM
Hi @Jhat
What booster do you have and where is it located in relation to the Q box and the Q Router?
Message posted on 07 Oct 2024 09:25 PM
I have the black SR203 model. Its in the hall , sky q in living room, same place that its been since I had sky q 5-6 years ago and never had this issue, wondering if it could be the sky q box playing up??
Message posted on 07 Oct 2024 09:30 PM
Message posted on 07 Oct 2024 09:34 PM
Yes i know it the router. The booster is upstairs where the sky engineer told us to put it, with sky mini box in back room downstairs. All been working absolutely fine until yesterday!
Message posted on 07 Oct 2024 09:40 PM
OK @Jhat
Without knowing the full layout of the router main Box and mini it's difficult to give any advice on connection.
When you get the message that you may need a booster this means that you need to connect to a booster that is located between your router and the Q box
Message posted on 07 Oct 2024 09:48 PM
Totally understand, we have one of the white se210 boosters. Its realy daft as its been working perfectly for a good couple of years then suddenly won't work! I need to phone sky about renewing contract tomorrow anyway so will mention this also.
