Discussion topic: Sky Q box will not turn on and does not full shut down (yellow light)
Message posted on 10 May 2025 11:16 AM
Hello
In the last week our Sky Q TV box has started to run off randomly (blank screen) and sometimes it will not start.
Power cycling and forced reset of the box has brought it back to life so far, but this feels like a problem getting worse.
When in 'standby' the box continues to whirr (i.e. forever) but not sure if this is the hard drive or the fan. The light in the button shows yellow in this state, turns green once you can get the box started.
I tried calling Sky but ended up getting a text and guidance saying enquire with the community! Not sure how to talk to a techie or get a replacement box.
Suggestions welcome.
need a long term fix asap
Message posted on 10 May 2025 12:26 PM
Re: Sky Q box will not turn on and does not full shut down (yellow light)
@jonathanfrancis wrote:
Hello
Message posted on 11 May 2025 08:47 AM
Thanks Oldfella. We have had grandchildren stay at the weekend so have not wanted to try anything with Sky Q whilst it is working!
The box seems to have been working normally for the last 48 hours and overnight the noise from the box has reduced to a gentle hum, which from the blogs seems to be normal.
Perhaps the power reset cleared some issue. We'll see what happens during the coming week and keep the 0-0-1 reset in reserve to try if needed.
