Discussion topic: Sky Q box will not start. Loops through reboot hello screen over and over
Message posted on 03 Jul 2024 09:11 PM
Came to watch the tv this evening and the sky Q box will not load. Just loops though the reset screens, over and over. How do you reolve?
Message posted on 03 Jul 2024 10:14 PM
Re: Sky Q box will not start. Loops through reboot hello screen over and over
Hi @GeneralGary
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box.
Message posted on 03 Jul 2024 10:46 PM
Thank you! How long will I be without TV? There's an important tournament happening and the British GP!
