Discussion topic: Sky Q box whirring and not turning on
This message was authored by: Rmgriff
I've rebooted a few times but it continues to whirr and beep and doesn't turn on
Re: Sky Q box whirring and not turning on
Hi @Rmgriff
Have you tried switching the Q box  on using the Standby button on the front right of the box  (the Amber led)?
If this brings the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
