Discussion topic: Sky Q box turns itself off and reboots
Message posted on 22 Oct 2024 04:37 PM
Really annoying when watching programmes and Sky Q box turns itself off and reboots
Message posted on 22 Oct 2024 06:33 PM
Re: Sky Q box turns itself off and reboots
Hi @Sandra03
Message posted on 23 Oct 2024 07:35 AM
Thanks have done as suggested so will see what happens.
