Discussion topic: Sky Q box taking an increasingly long time to display show on TV
This message was authored by: HimTerrier
My main Sky Q box is increasingly taking an inordinate amount of time to display on my TV. I was an early adopter and have had the box since Q was released. Do not have the same problem with the two mini boxes, just the main box. Sometimes it just switches the TV on but does not change the source to the Sky Q box. Cannot find any help on troubleshooting with 'My Sky' so seeking advice.
Re: Sky Q box taking an increasingly long time to display show on TV
Hi @HimTerrier
Try a Reset Settings in the main Q box hidden menu.
Avatar for HimTerrier
Thanks for coming back to me and I was just going to try your points but I now cannot switch the box on. It just has a red light. When I reboot it  the screen says HELLO then tells me it will go blank for a while which it does but then stays blank.  I am Going to unplug it for a while and see if that makes a difference . I will se what happens.
Tried the sky Help Line and the Box sprang to life.  However, after experimention I find I am having these issues only when I switch on after a long period off.  I need to trial this a bit more but I then have to restart the box, switching off then on, to get it to work.
