Discussion topic: Sky Q box taking ages to change channel and only part recording programs
This message was authored by: TC1106
My sky Q box takes ages to change channel and sometimes screen just goes black. Also when recording anything it says only part recorded and when I press home button to go to recordings or tv guide sometimes there is no pictures being displayed only text
Re: Sky Q box taking ages to change channel and only part recording programs
@TC1106
First thing to try is rebooting your main Sky Q box.
~ press the 🏠 button
Avatar for TC1106
Hi thanks for reply and I have already done that it helps for a short period then plays up again
