6
This discussion topic has been answered Discussion topic: Sky Q box stuck on standby
This message was authored by: nomes
My box regularly fails to start up correctly and I have to do multiple switch off and back on again to get it working. This time it will not work at all. Just the standby light showing.
Avatar for nomes
This message was authored by: nomes Answer
Re: Sky Q box stuck on standby
Thanks I have reset the remote as per guidance and it is working now. Thanks for your help.
Hi @nomes   What happens if you press the on/off button on the box itself?
Avatar for nomes
 Nothing happens unfortunately
Avatar for nomes
I held the button down this time and it is flashing  (orangey/ yellow colour)
Avatar for nomes
Started the box up again and pressed the on off button and it worked ( stupidly I had been pressing the WPS button previously), it is dark under the TV !!
Avatar for nomes
