Discussion topic: Sky Q box stuck om 1 of 2 updating steps
This message was authored by: mark7373
My Sky Q box has been stuck on step 1 of 2 software update steps all day, we have turned off an on and done everything suggested but it is starting to get annoying.
Re: Sky Q box stuck om 1 of 2 updating steps
Hi @mark7373
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
This message was authored by: Tw5
I have the same issue
