Discussion topic: Sky Q box, some News channels Inc GBNews not available for 3 weeks
Message posted on 28 May 2024 05:28 PM
On my Sky Q box, at least 5 channels in the News section have been unavailable "this channel is affected by a problem with your satellite signal" since 14 May, e.g. 502, 506, 511, 512 and 513. There may be other channels affected. I can't find any reason for this online, can't find a Help phone number. One is Al Jazeera, one is GB News, have they ceased broadcasting?
Message posted on 28 May 2024 05:35 PM - last edited: 28 May 2024 05:37 PM
Re: Sky Q box, some News channels Inc GBNews not available for 3 weeks
@Tim84
Last year GB News moved to a different transponder that has a wider footprint which may result in a misaligned dish losing the channel.
If a “no satellite signal” message is displayed, that relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company who deal directly with their approved engineers.
Message posted on 31 May 2024 01:38 PM
Thanks for this.
