Discussion topic: Sky Q box slow to respond to remote
Message posted on 08 Mar 2023 11:34 AM
Its taking 30 seconds or more for the box to respond to a command from the remote
Have tried new batteries
Message posted on 08 Mar 2023 12:10 PM
Re: Sky Q box slow to respond to remote
@Dajumari Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 08 Mar 2023 12:19 PM
Hi @Dajumari
If a Reboot doesn't help
